Steering Shroud Removal?
Fast Too
Linden, VA
I have removed the two screws at the front of my steering shroud, but cannot get it apart. Are there screws in the back I am not seeing or does it just snap together where it enters the dash? I don't want to break this thing getting it apart. Anyone have insight as to how that comes out once the two front screws are removed? Oh ya, this is an 06 coupe
Racer Robbie
Guilford, CT-USA
Here is the link for All-data fir the removal of the lower steering column cover.
http://www.alldatadiy.com/alldata/AFI~V11365106~C37885~R0~OD~N/0/89012112/97272320/97272321/97272324/34853741/34864218/34864219/56494365/55275237
Service and Repair
INSTRUMENT PANEL STEERING COLUMN COVER
WARNING: Follow all Warnings for airbag component service. Refer to Airbag System.
REMOVAL
Fig. 1
  1. Remove the two lower screws. (Fig. 1)
  2. Using a trim stick C-4755 or equivalent, separate the upper clips.
  3. Roll the left side of the cover down and separate the clip on the right side at the tunnel.
  4. Disconnect the adjustable pedal switch electrical connector and remove the cover.
INSTALLATION
  1. Connect the adjustable pedal switch electrical connector.
  2. Position the cover into place and seat the right side clip at the tunnel fully.
  3. Roll the left side of the cover up and seat the upper clips fully.
  4. Install the two screws at the bottom of the cover.
F
Fast Too
Linden, VA
Thanks Robbie, I got it off. I only wanted to remove the upper shroud to mount a gauge pod. After a bit of finesse it came off. I'm not one to force things that I don't know how they come apart. All is well and back together now. Gauge Pod from Dave's Big Brake's worked very well for anyone looking for a pod.
Racer Robbie
Guilford, CT-USA
BarryLB
