old userwith p/s problem need help on 2006
Morristown,NJ
Hello Rich here from NJ. Bought my Viper in August 2006. Got rid of my 06 Zo6 plague with issues. Now 20 years later still lovin my Viper. Has 26000 miles and runs good except for the surging under 2000 rpm. When I got the car first week I removed the entire exhaust header back, no cats, mufflers cross over pipes just straight from the header to each side. then installed a 354 rear and a 170 thermostat. I had issues with the top pressure p/s hose to pump fitting. First time I bought an original end with the o ring and cut the old one off lasted a bit then pulled out and made a mess. So I bought new lines from Havik Performance. Seemed to be allright you screw the adapter to the pump and fan module it has a o ring and looks like plastic or maybe alum. after a few months driving the power steering went away and the car ran hotter. This happened at 60 miles an hour and the oil went everywhere. Seems the adapter loosened in the fan module. I think because the hose can move a bit and loosen itself. Try to put it back with new oring but maybe use lock tite or ??? any ideas or is there a better hose made.
Old School
North Alabama
I went through a power steering hose replacement phase, fixing it a couple of times on my Gen3. But the real problem turned out to be the relief valve in the pump being stuck.
I went with a combo setup of new and old pieces fused together. I originally bought a set of JTSVP fittings/hoses for my setup, but I never liked the way they fit. The kit had lines for multiple hoses (pump to fan and fan to rack), but I only wanted to replace the pump to fan one as it was the only one causing issues. I think they sent me a kit for the SRT-10 truck though as they just didn't seem to route in a way that made sense. In the end I actually took the factory line to a hydraulic shop and had them braze on an AN style fitting that mated with the adapter that came in the kit. That kept my original hose routing that was way nicer, but gave me a more secure connection at the pump. I've been happy with it.
A
Morristown,NJ
I had the PS problem main hose from pump tried the havik system it failed twice in 100 miles crappy fittings then went to viper parts for 500 dollars more and they insist you replace the pressure valve in the pump except might have to remove the pump from car to do it and they use a short hose routed straight from the pump to fan but one fitting they had to fan was easy bolt on, but was not going to replace the pressure valve etc so I went to JSP racing and guess what they had the best fittings for the pump and fan just like the original factory fittings and they work great so best ps fittings are JSP racing and the nicest most helpful people
A
Morristown,NJ
ok i got the ps fixed ok the havik was just not reliable so I went to viperparts and paid 469 for their kit which included very short hoses direct to fan mod and was necessary to change the ps pressure valve to get a fitting to fit the hose and may make it necessary to remove the pump from the car to do it. That was BS. so I went to JSP performance and bought 2 adapters one for the pump pressure line and the other for the fan mod it then was easy I just screwed both adapters in and hooked up the original lines that came with the havik kit the people at JSP were the nicest the guy at viperparts would not take the kit back even though I did not use it. now the line is secure the adapters JSP makes were 30 dollars and fit exactly as the original hose fit best way to go the havik kit relied on the o ring to seal when you tightened the adapter not the right way the factory seal on the hoses or adapters were the same so I lost the ps fluid 3 times and spent 900 dollars with a lot of aggrevation just get the stuff from JSP performance the belt and brakes and the alternator were soaked 3 times by that crap people sell.
africanbusiness
