suspension crunching sound
HiYoSilver
Lake Success,NY
I have isolated the sound to the left rear and it is a "crunch" that occurs with small road irregularities or on quick turns which shift load onto the suspension abruptly. Guess I'll have local Viper Tech look it over in detail. :usa:
Skip White
Kingsport TN
Coil spring has jumped out of it's perch, I would suspect. Not very common.
Let us know when you find out.
Skip White
Leonard Knight
Glendora, Ca. USA
I had the same sound. I was having some other work done at DC Performance and they found that one of the sway bar attachments was loose. You might check this too.
Leonard
tbone96
