TPS wire location
isanti
Minnesota
I am looking for the TPS wire for a Gen 1 viper. I was told to grab it off the drivers side TB but what wire should I use? I tried searching and was having issues.
Thanks in advance,
John
RTTTTed
??? Shouldn't there there be 3 wires on the TPS? Even my old Daytona uses 3 or 4.
Jack B
NE Ohio
There are 3 wires, I need to know which one to tap for my WOT switch.
use an insulation piercing clip and voltmeter to check for the wire that shows a range of 0 to 4.5 volts when the throttle is depressed.
V10SpeedLuvr
According to my 96' RT service manual, the 5 volt supply wire is solid red. FYI, I looked on my car and the red actually looks orange.
Just for additional info, the other 2 wires are:
sensor ground: black/light blue
TPS signal: red/dark blue
I
isanti
Minnesota
hmm.... I checked my manual and it called the center wire (red/blk I think) the output wire so that is the one I used. It is used to check the TPS, I would assume the others are power and ground... I will know for sure when I test my controller in a couple of days.
Thanks,
John
martyb
IL
John,
I think you are right, my manual also states the center terminal wire. Let us know how it goes!
martyb
