I just installed a Autoform Spoiler. The trunk is now heavier. I need larger struts to hold it up. Does anyone know who makes larger struts or where to get them? Thanks
I have the Autoform spoiler also and have the same issue with the struts . No instructions except how to mount the spoiler were provided . The weight issue is most pronounced in colder temps. Last year I got whacked in the head when I did not expect it to close (may be the cause of ...).
If you go to your local NAPA store with the existing strut you will be able to look up a listing of all the struts available along with the psi of each strut so you can compare it to your OEM one.
