PhoenixGTS
Went to see the tech who will be fixing my improperly done Recall 998 (plates are on backwards so the oil filter is trapped). He showed me his theory as to why techs do it backwards. On each triangular plate has a parts number sticker. One says right and the other says left. Those stickers are on backwards (i.e. on the wrong plates), and due to a contour in the plates, the only way they fit to match the stickers (which the techs assume are correct) is to install them backwards. Additionally, the hole in the steering rack cross-member associated with the recall is in the wrong place. Bad thing is that you cannot leave the improper plates on (I think I could fish the oil filter out of there) as they the proper positioning overlaps the improper positioning. There are no cracks evident so the fix will be easy.
Here is the good part. The invoice for the recall also indicates they did the rear recall work. But, there is absolutely nothing done in the rear. I am sure Dodge is going to be real happy to hear they were billed for work that was not done. In any event, it will be finished early next week and the tech knows of two parts cars so He is getting me a used HVAC fresh air box that got cooked by the leaking old headers.
