upgrades
Serpent 97
Vancouver
Hi all,I'm new the whole viper scene.I'm in the process of upgrading my exhaust system and I have narrowed it down to the following,SVS headers and Corsa cat-backs.I was wondering if there are any board members that use this set-up or does it matter performance wise.The other choice I'm considering is just going through the Mopar high performance catalogue for the same parts.Also what are your thoughts on a 180 degree thermostat.Any help or advice would be greatly appreciated.Btw, my snake already has the smooth tubes and 3:55 gears.
MES
Sarasota, Florida
You should also consider the Belanger headers and Corsa cat back. That's what I have, it's a good combo. Skip the thermostat unless your going to replace the intake for some reason. Get the newer fan with shroud instead if your worried about heat.
Serpent 97
Vancouver
Thanks all for the feedback,I just want to make sure I get the right set-up for my car.With so many options and vendors(well not that much compared to a mustang or camaro),it can get confusing.Unlike you guys down south,there doesn't seem to be that many snakes around.Based on that,it's even harder to find one locally with mods for me to check out and then make a decision to buy or not.Eng12,my car is a 97 GTS blue/white stripes with about 15000km.So thats about 9000m.
