Valet Mode
Sean_02GTS
Pittsburgh, PA
I just in the past few weeks became the owner of an 02 GTS. The car most hasn't been driven in the past 4 months or so. I got it fired up and when I put it in gear and let the clutch out it barely moves. Forward or reverse. It doesn't feel like a slipping clutch and I was curious if there is some kind of valet mode that may be on. The car has been garage kept and maintained very well.
Curious to know if you have checked the clutch fluid reservoir.
Last year I got a similar call...car had been sitting for a couple of years...brake pads allegedly stuck on rotors.
P.S. No such thing as "valet mode" on your Viper.
Sean_02GTS
Sean_02GTS
Pittsburgh, PA
Thank you for the response, I will check the reservoir. Makes sense about the valet mode, but was hoping.
CassVaishnavi
Canada
Here you need to pay attention to several factors:
1. Check all fluids
2. Clutch
3. Brake
This is a standard set of what needs to be checked in such a case, experts write. If this does not help you, then contact the nearest service center for help from specialists.
