VEC3
gen2lover
Windsor,Ontario
will a gen 2 rt with a VEC3 pass an emissions test? Never had one before on any car I have owned.Here in Ontario,specifically ("Drive Clean Program")
thx in advance! Kevin.
RTTTTed
A "Viper Engine Controller" allows you to adjust the tune for better emissions. It also allows you to adjust your tune for bad emissions. It allows adjustments for optimizing the tune of your car.
Whether it passes emissions or not (snif test) depends on how it's adjusted.
Ted
RTTTTed
The Vec allows you to adjust for Forced Induction, different sized injectors, individual injector pulse widths, etc.
The Vec atually allows you to adjust the tune for the modifications to the engine's demands for timing and fuel which allows the engine to make optimum hp. The Vec allows adjustments not supported by the factory ECU. Forced Induction needs completely different programming for the boost pressures in the intake and the Vec has an internal MAP sensor that allows tuning according to Manifold pressures and loads.
Larry M (Macedo?) you can listen to what he says since he has vast experience in this field.
Ted
