I put this information at the tail end of another post which is drifting onto the back pages, so I'll give it a post of its' own, just in case it's of use to someone.
I modified an OEM oil fill cap to in an attempt to be able to vent to atmosphere without losing oil using a plastic pipe fitting.
The fitting is angled towards 10 o'clock or so as it sits on the valve cover. I run a hose from it upwards from it, behind the intake manifold and high up near the underside of the windshield cowl from the passenger side towards the driver's side and add a small filter on the end of the 2' or so of hose.
Drilling out the center of the OEM fill cap for the plastic fitting also takes with it the inner works that locate the 2 piece cap to its' threaded base. It'll now just spin on the base when put back together, so I cross drilled the underneath of the cap to locate the two pieces of the cap where I wanted them, then ran a long pin through the entire assembly. You can see it sticking out of the bottom of the filler cap.
The hose angles uphill enough from the valve cover to the underneath of the cowl cover (base of the windshield) that any oil coming out of the filler cap should just drain back into the valve cover.
There's a small aluminum box underneath and in the center of the cowl cover, I've secured the hose in its' elevated position by clipping over the top of that box.
