GoldMan
After researching the installation of vinyl stripes, many experts suggest cutting each end about 1/16 to 1/8 inch back from the edges. They say this helps prevent the ends from peeling back & looks more like painted stripes... However, most info I've found on this forum (including the "how to" section) says to apply the stripes over the gaps (door, trunk, etc) & then cut down the middle & "roll" the stripe over the edge.
Which is the correct/better way to finish the edges/gaps ???
When applying stripes over the shallow "crevice" that goes around the hood duct (where the duct attaches to the hood), do you leave the vinyl in one piece & push it down into the "crevice" or cut it & push it into the crevice ???
Any advice or tips about these questions and/or other techniques would be appreciated !!!
