Viper body screws and bolts
Nixon's SRT
I seem to be missing a few body screws and bolts. I went to Lowes and nothing matched up. Anyone know if anyone has the matching body screws and bolts. Im missing 4 bolts on the shield under the car, my side sills are missing all the bolts underneath except 2 on each side. and a few screws around the wheels.
Anyone know where to pick those up locally or should i just contact one of the vendors on here.
quick pictures of the sill bolt and screws on the panels
Darbgnik
Fort McMurray, Alberta, Canada
So do all the bolts holding the bottom of the side sills look like the one on the left?
Most of mine on the bottom of the sills are missing as well, except at the rearmost end. I saw those hex bolts and assumed the last tech shoved in a couple odd ones he had laying around.
Seems every month or so I lose one or two more of the regular body screws like the one on the right.:dunno:
What's the common way to keep em in?
slysnake
I replaced a couple of them with those push in tabs like hold the hood pad on. worked well.
fastandloud
Frisco, Texas
Same issues here...maybe try some blue loc-tite???
For the sills I believe you need PN 6102 132AA and here is a list of all the pn's to the various screws and bolts that hold the REAR shield on if that's what's missing..I'm missing some of the 6505 070AA's listed here. Do a search online, you might be able to find em!
1 5290 078AE qty 1 BELLY PAN, Rear
2 6505 070AA qty 20 SCREW, Pan Head, Rear Belly Pan
To Frame
3 5290 221AB qty 2 EXTENSION, Floor Pan
4 0152 493 qty 4 NUT, Heat Shield to Rear Pan
5 5290 247AA qty 1 SHIELD, Heat
6 5290 137AD qty 1 BELLY PAN, Extension Rear
7 6035 625 qty 4 SCREW, [.190-16x.750]
8 5136 832AA 1 qty 27 PANEL, Fuel Tank Close Out
FLX109
Massachusetts
Get a tube of clear silicone chaulking and squirt a dab on the screw before you install it and it will be fine, works great.
Bird325
Ft Worth, Tx
My tech warned me that a lot of the screws/bolts are metric on the head and standard on the threads ... causes a lot of confusion. May be part of the problem you were having.
Viper Wizard
South Salem, NY USA
I keep them in stock, as many as you need.
914-763-3136 :cool:
Jandrix302
