Viper - Maintenance - methods
fed007
Hi, I am curious to know what you guys use to get under your viper. and to qualify this I am a regular guy without a fancy lift.
I want to do all my own mods and service so having a good system is key.
Are there certain jacks and stands that you guys have found ideal for a viper?
thx
Neil
dave6666
I use Race Ramps XT and then 2 quick pump floor jacks to lift the back and put it on stands. Spent about $700 and it all fits in a closet when I'm not using it. Car will be up 10" and I've yanked the tranny several times from that height.
Here's a pic up in the air when I was doing my exhaust system. I built some wheel stands to yank the ramps out of the way for better access depending on what I'm doing. The ramps can be a PITA to crawl over, but they fit in a closet when I'm done with them. ;)
RoadiJeff
Wildwood, MO
I've found that a low profile jack like this one from Harbor Freight works well. That and 4 Craftsman jack stands is about all I need to do maintenance under my car.
Ricketts
Fayetteville NC
Here is what I use :D Swing by, you're more then welcome to use it anytime!
viperdude118
Poplar Grove, IL
Sears has an aluminum race jack, it is on sale this weekend for 159, if you are a craftsmen member, if not its like 179, but still not bad, it fits under the viper.
Callaghen
