wax
ohiodoc
Las vegas, NV
I am buying my first viper in the next month or two. What is the best wax to use? I have seen alot debate about this before. What does the best wax cost and where can you get it.
Snake Bitten
Southern Kalifornia
Search button!
Pinnacle Soveran...they have it in liquid now...Zaino Z6 or Pinnacle mist in between each coat...
Microfibers and quality foam applicators...
Cost is not an issue when it comes to your vipers finish...
ViperJoe
Virginia
Many say if you don't Zaino, you have no braino!
My car had been Zaino'd before I picked it up, and I must say that I NEVER thought a silver car could look so good. VERY deep and shiny. I probably woun't Zaino myself due to all that wash with dawn, than step this and step that, etc etc.
Hot Rod
Allen, TX USA
I've experimented with quite a few waxes and polishes. Been using Zaino for quite awhile and was generally happy with the results. Zaino requires patience as the cure time can be long depending on temperature and humidity. I've let it set overnight a couple of times before buffing off.
When I don't have the patience, I've used Eagle One Wet, which is pretty good, and recently started using 3M Show Car car (paste) wax. I usually follow up with a spray gloss enhancer after waxing or polishing - Zaino or Eagle One. I'd also highly recommend clay bar every couple of months. Takes about the same effort as applying wax. The paint will be as smooth as glass.
