What did they do to get the hp boost for the Gen2 cars?
Nuck
Alberta
Was it a bunch of here and there tweaks or was there some major internal changes?
Nadine UK GTS
Bath, Somerset, UK
For starters they improved the cooling system and raised the compression ratio slightly, GenII has different engine castings with cross bolted main bearings; the motor was something like 80 lbs lighter. Changes to ECU.
Jack B
NE Ohio
Injectors, headers, exhaust system, cam, PCM, compression, heads and coil packs were the major changes. The Gen 1 rated hp (400) was lower than reality. The Gen 1 also had a a very restrictive exhaust system.
Ross L
