What oil grade???
93Cobra
So Cal
I personally use Mobil 1 and I am about to change the oil on my 97 GTS. If you guys use Mobil 1, which one do you use, 10-30, 20-50 etc? My GTS has 21k miles on it and though using 20-50 would be to thick. What do you guys think?
3snakes
my oil cap says m 1 10/30 . owners man. chart says it all if you go buy the temp.
Cape Coral, FL
As long as the engine is in good condition, 10W-30 will be fine. Oil pressure at Hot Idle should be between 30+ for a good condition engine. Do not use 20W-50 if you live in a colder climate, it will be too thick.
ctrengine
