wheel hop inf.
3snakes
I have read alot of the threads on this .I know about wheels left or right when you do aburn out an that works for me. but when going form 1st to2nd gear i get a lot of wheel hop have to easy on gas . iput ver. shocks on two of my cars took care of this. has anyone done this. thanks for any inf .
GoldMan
Orlando, Florida
I'm a new owner & not really used to the car yet, but I seem to frequently get alot of wheel hop going into second also.
Other performance cars I've owned did not do this...
Any more input on this ???
3snakes
what is wrong posting form a pho. if that is all that is avb. 10 miles away from cable sorry if it did not fit your need?
Tom F&L GoR
Wappingers Falls
Some wheel hop can be tuned out with tire pressure and rear shock settings. The tire is a spring, too, so a little higher or lower will change the wheel hop characteristics. The shocks are set full soft, so have to go stiffer. Unless you stiffen the fronts also, I wouldn't recommend more than half stiff in the rear, as it will make the car (more) prone to corner entry oversteer.
Mando9595
