Where is the OBD2, or DLC found?
2000GTS
Miami, FL
I want to program a new remote.
The instructions say " As #2, but instead of C13 you're grounding Terminal 1 of the DLC. (9/30 update...Ron found out that DLC is the Data Link Connector, i.e. the under dash OBD2 connector which is above your left knee )"
I can not find these connectors. I took the knee panel on the drivers side down, but couldn't find it there either. Does anyone know where it is?
Russ M
LA, California
It is not behind any panel, it is under the dash on the left side, cant miss it. It is a rectangular plug for the obd scanner. Hope this helps
