Where to buy StopTech Calipers?
VIPER GTSR 91
Spring, Texas
I have a 99 GTS with the complete StopTech brake system in front but the back only has the rotors and stainless lines that StopTech uses but with oem calipers. Where is the best place to find just the StopTech calipers (in red) for the rear? Thanks.
mbccenter
Legacy Supporting Vendor
Forest Lake, MN
I have a complete set used in red for about the same price as just the rears and you could sell the fronts!
SoCal Rebell
Mission Hills, Ca USA
I bought 4 Big Rotors, 4 Calipars, new Axxis pads for all 4 corners and 4 SS brake lines brand new for $3,600. If you don't have 18" wheel you can't use the 355mm rotors.
PartsRack is usually StopTech's # 1 Viper Vendor....an honor we share and swap perodically with ARCHER-MN, another fine VCA vendor.
You DO have a safety issue: The 2-wheel big-brake upgrade kit you have is NOT a simple matter of "add 2 rears later." It does NOT work that way! STAY SAFE ! DO CALL A STOP-TECH SPECIALIST, or call STOP-TECH TECH SUPPORT !
Missjazzyfitness
