Why doesn't oil leak from the main cap crossbolts?
FE 065
MI
Why doesn\'t oil leak from the main cap crossbolts?
There's nothing in the service manual about any kind of gasket material or O ring for the cross bolts.
Is it just the close tolerance fit of the main cap into the block and the compression of that tolerance when the cross bolts are tightened that prevents any oil from seeping out?
FranciscoR.
Cincinnati, Ohio
Re: Why doesn\'t oil leak from the main cap crossbolts?
FE - If you want it to leak so bad, just start hitting it with a hammer...lol... :rolleyes: :p
F
FE 065
MI
DOH!
SNKEBIT
western wisc.
I don't know the answer but if it's was me I'd put some thread sealer or black silicone on the bolts during assembly!!!!!
.......... or, you could bypass that step and go with the hammer!!!! :eek: :D
F
FE 065
MI
.. I just thought someone who's had one that far apart could tell me if there is any type of sealant not called for in the service manual.
If there isn't, then it has to be the tight machined clearances of the main caps.
FranciscoR.
Cincinnati, Ohio
A small amount of sealant could only help and not hurt the car. Just go buy some $5 sealen from PepBoys or even Walmart...Should provide that extra bit of security you're looking for.
SNKEBIT
western wisc.
I agree, a good black silicone would be what I would use. DC mechs use something like that I'm sure. Wouldn't take a chance on leakin' and have to take it apart again. :eek: :eek:
F
FE 065
MI
Thanks for the sealant tips, but mine isn't apart, and I don't plan on taking it apart.
I just wondered it there's anything more than metal to metal contact sealing the bolts as delivered from the factory.
SNKEBIT
western wisc.
There has to be, dc might build an awesome engine but they didn't go that far!!!!!!!
