Will Hoosier R6 315's fit up front ?
ACR steve
NY,Rockland
Guys, will the R6 315 on my stock rims fitup front with no rubbing issues ? Also if you run with 315's up fronthave you made alignment changes of your normal track alignment to compensatefor a larger front tire? any slower turn in issues or other issues developbecause of the increased front grip ? Thanks
Omaha NE.
Works just fine, better on an 11" rim, but will work fine on the 10. Camber should be 2.5 neg if possible and you will have to fiddle with tire pressures till you get it right. Front dampening rates may be stiffened up a touch also.
majic26
