02 RT/10 Air Intake Performance
Robert Dyck
Pembroke Pines, FL
I'm wondering what others have experienced with air restriction on the OEM NACA port with the stock intake box.
I have the stock system with K&N's and smooth tubes.
How beneficial in hp gains is it to go with an aftermarket system that draws air from under the hood with a heads and cam mod?
Does anyone have any dyno results for this?
Thanks again.
GTS-R 001
California (north)
If you are grabbing air form under the hood, you will lose power as your intake air temps will rise, which will cause you to lose power
