I just put a paxton, random tech high flow cat, and corsa track II cat back exhaust on my car and here is the dyno sheet. Im running factory plugs. Suggestions, remarks, the boost gauge read 9.2 lbs, seemed high to me. What do you guys think.
Those are great numbers. They are above the average for the stock kit with your mods which is usually about 650/600 based on the data on this site. What octane fuel was used to do the test? Your A/F after 5000 RPM trends up until it appears to be 13 at 5900. Some would say that A/F is OK. I think that it is a tad lean. The 9.2 lbs of boost is above what the stock kit normally generates so something is happening. Assuming it is not a faulty gauge, it is probably worth it to find out what accounts for the 9.2 figure. Enjoy your snake.
Based on the results from the other two cars, I would say that it may just be that the dyno needs some calibration. Do you have another shop where you can have it retested on the same type of dyno?
doug is great guy will not steer you wrong. was your fuel preasure over 100psi mine went to about 110 ..
the 1.855 is a 6:1 anf the 2.22 is an 8:1 and i think it says to use that for his year. but make sure that if you did change the washer in the fmu that everything alligned up right with the retainers and stuff.
I bought the unit used, it came off an install by woodhouse on another 06, Im sure they used the right washer, but I will check.
when they dynoed it they did not take a fuel preasure reading? also did they pull an o2 sensor out and install a wide band one in there when they dynoed it or did they stick a sniffer in the side exhuast?
I did not watch mine gauge during the run, I should have.
I've got an 06 coupe with the same mods that was putting out the same HP.........right before it went KA-BLAMM-OOOOO!!!!!! . Did they tell you not to drive it hard if the fuel tank below 1/4 tank? Definatley monitor your A/F and fuel pressure or suffer the same fate as I did.
Thanks for the heads up, I did the install so I need to tell myself . Did you loose fuel pressure? What was the damage.
Why is it the case that below 1/4 can cause you problems? At that point does fuel not come out as fast from the tank? That seems like it should of been a recal problem even if you are not running boostGreg...I keep reading about fuel starvation...make sure you have at least 1/2 a tank of gas on that bad boy if/when you open her up...
