1997 Viper GTS Hood Question
WinstonCupDad
Kentucky
Hello, Family
My son's 1997 Viper GTS' hood will not stay up on its own. With the design of the hood and the way it opens, the hood has too much weight for the supports to allow it to remain up without the aid of a stick or an external rod.
Do you guys and gals have any tips/tricks/fixes so that the Viper's hood will stay up on its own without any help? Thank you, guys!
Jay Lopez
Dallas, TX USA
You have to replace the springs. I had it done in my 97 quite a few years ago. You might have a hard time finding them. Try Partsrack
Mopar Steve
Newark DE
Often people mistakenly lubricate these and they fall too easily. Spray the hinge/spring with a liberal amount of brake clean. Let it dry, and you should see improvement.
Free2go
That's right. Then clean it again and then again. Worst thing you can do is lubricate the damn thing.
*****absolutely no sarcasm was used in the above post.
W
WinstonCupDad
Kentucky
I just got new springs for $20 each.
Just put these p/n's in the search field. One is left and one is right.
4709075
4709074
https://moparonlineparts.com/mop-parts/#parts
Do I need to order both parts (both numbers that you have listed)? I am not sure of the name of the part, nor do I really understand the different numbers on the diagram that pulls up when searching for the parts.
1. Do I need both parts?
2. When looking at the diagram that pulls up, do I receive all of those pieces or one of the individual pieces? I would like to see what I am ordering.
Braunstein82
Need to order both, one is left other is right side. Comes with the entire assembly from where it mounts to car all the way to where it mounts to hood support frame. The diagram is misleading.
xeng yang
