2" Seat Lowering....Mayday, Mayday!
Bravo
Middle Finger-Fingerlakes, NY
Well I finally got a kit from a Viperclub.org member. The kit is fine, but just looks really impossible to install the rear mounts.
Viper is 2000 ACR, the kit looks Northwind.
Iif I remove the hog rings in the front, remove the seat tilt cover, pull back the plastic hook in the front and peel the cover back, then I might be able to weasle the bolts in between the foam and through the pan to attach to the rear mounts which must be mounted to the floor first.
How then do you get the cover back on? It is wicked tight to the sides in the first place, and lowering the seat makes "the cork tighter in the bottle".
I spent the evening last night searching again for a diy / how-to with pics. Nothing but an older model that used the metal hook type fastener for the lower cover.
I really want this to work, but it's a PITA for sure.
wastntim
Orland Park
I don't believe you will be able to use the side hooks again. You will only be able to latch the front.
dave6666
I went with the 1" adjustable kit as I anticipated exactly what you are having to deal with. It was a pain enough. But at 6' 4" I could have used the extra inch in my GTS. Good luck...
HLN A55
Austin, TX
Correct. I was unable to get the side to hook down. Other than that, just squeeze yourself between the foam and the frame and have at it.:2tu:
JKGiant
