2003-2010 Dodge VIPER SRT 3" Exhaust Flex Mid Pipe w/o Cats
Vipermann
Texas
Listed FS Here: Gen 3-4 3" DIA Flex Mid Pipe w/o Cats
ONE SET OF TWO FLEX PIPES (LH & RH) 3” DIAMETER TO STOCK MANIFOLD – INCLUDES 3” HIGH-FLOW FLEX MID PIPES WITH-OUT CATS. REPLACES FACTORY 2.5" PIPES & CATS. CONNECTS TO FACTORY MANIFOLD AND 3” SIDE-EXHAUST.
THESE WERE PREVIOUSLY AVAILABLE FOR 'RACE-TYPE' EXHAUSTS W/O THE NEED FOR HEADERS, WITH AFTER-MARKET 3" CORSA OR BORLA, AND OTHER 'RACE' SIDE EXHAUSTS. APPROX 22" LONG FROM STOCK MANIFOLD, AND 8" FROM CURVE TO SIDE EXHAUST.
MAY NEED AN ADDITIONAL SMALL 3" DIA PIPE SECTION, OR ADD HIGH-FLOW CAT, BEFORE SIDE MUFFLER TO CONNECT TO SIDE PIPE, DEPENDING ON WHICH BRAND OF SIDE EXHAUST USED.
THESE WERE ORIGINALLY PURCHASED FOR 2005 and 2009 VIPERS. I HAVE TWO SETS OF THESE AVAILABLE - $375 FOR EACH SET, OR $695 FOR BOTH SETS.
NEW - NEVER USED.
Nolyaw
NKY
Do they have the bungs for an O2 sensor “test port” welded on the pipes? Thanks
pehamm
Houston
Well shit, I ordered & have been waiting on my 2.5" mid-pipes+hi-flow cats & flex pipes for a month. Being stock diameter, I don't think this setup would work anyways without getting a 3" catback... but you tell me, could any of these part out onto my setup? I'm in Htown by the way.
Vipermann
Vipermann
Texas
No, I *think* when I used similar (if I remember correctly) I only ran bungs after these race pipes and with some high-flow cats, and then then O2 sims - the bungs were with the cats (but I guess you could decide where to have bungs welded in)? in the side sills ahead of Borla/Dodge side race mufflers... 'if' I remember correctly - but I am sure that my set up used only one set of bungs and O2 sims for the other. I think basically, the O2 bungs helped the engine run optimally, and the other O2 sims told the CPU "everything was fine."
Vipermann
Vipermann
Texas
If you place a small 3">2.5" reducer piece after these 3" pipes (going to your new high-flow cats, assuming they are separate cats), they should work instead of your 2.5" flex pipes.
JoeC
Savannah, GA
NEW - NEVER USED.
Hi Vipermann,
I sent u a pm too, but wondering if either set of catless flex pipes were still available? Thx in advance
-Joe-
