MES
Just got back from Moroso and had the unfortunate experience of a 3rd to 2nd gear shift at 100+ MPH when I wanted to go to 4th. Car is fine but I have a question. Is there any built in safety mechanism in the drive train to prevent damage? I thought I read here before that the clutch was made to slip under such high loads to prevent blowing the motor. When it happened I seen the tach go to about 7,000 RPM and the trany made kind of a strange noise kind of like a spring being wound up. I was not under throttle at the time had my foot completely off the accelerator. The reason I think there is one because the car did not decelerate hard it was just kind of coasting. I have seen others do this stunt and come out fine as well.
BTW 2nd time to the track my times were not that good but getting a little better 12.7's 2.06 60' There was another 97 GTS there I don't know if he is on this board but he was getting 119-120 MPH trap speeds to my 113
with the same mods. I'm granny shifting and spinning off the line both of which I'm trying to work on
