720 HP is yours!!!!!
BadVenm
Leawood, Kansas
I posted this on the classifieds days ago, but it hasn't shown up, so here it is....
Roe S/C used 300 miles - polished and painted
ported and polished S/C intake manifold - modified from stock
VEC 2 updated with 2 cards
5 psi, 8 psi, & 10 psi pulley wheels
MSD Fuel Pump boost control
MSD 8.8 plug wires
180 degree stat and stat gasket
polished 70 MM throttle bodies
Jesel 1.7 roller rockers - 2lbs lighter per side than T&D's
Aluminum Flywheel
50 LB injectors
New Factory injector harness with new injector clips installed by Roe
Supercharger belt
Idler pulley
Modified Heads - ported, polished, chambered, bigger valves
3" Roe hi-flow Cats
B&B 3" cat cack
Crank keying kit and tool
Belanger 1-3/4" coated headers
Complete stock rear end 3:07 - change to the ratio of your choice
Valve covers painted and polished to match the S/C
Sean and I worked through the assembly of all these components to create a 715 to 720 HP car.
EVERYTHING is NEW unused, never installed, NEW.....except the S/C!!!!
I have chosen not to modify my ****** GTS.
$19,550.00 buyer pays the shipping. (complete pacakge sale, no parting out at this point)
Also I posted a set of HRE 546's in great condition with Pilots with 80% or so of the tread left. The wheel ad I posted 5 or 6 days ago and it hasn't shown up either????? I think I listed them for $4,250.00 buyer pays shipping.
[email protected] or PM
JimT 99RT
Reno, NV, USA
So did you get tired of looking these in your garage, or are you sending the car off for something bigger and better?
B
BadVenm
Leawood, Kansas
Jim,
I just decided not to mod this car. I kept going back and forth, mod it, don't mod it. I have only clocked 300 miles on it since I bought it. I've decided to let this one remain stock. The next one will get modded like crazy!
I've got quite a few e-mails about parting out, so i might flip and go to parting out! Everyone drop a note as to what you want, I will sell parts as soon as I can complete the list with everything spoken for!
B
BadVenm
Leawood, Kansas
Re: 720 HP is yours! Individual parts now for sale!
For all of those who have contacted me in regards to some items not all items, I am now parting everything out for sure.
It looks like the S/C will find a happy new home by Tuesday.
The Heads look like they will be bought on Monday.
Everything else at this point is up for grabs.
BUT....please do not waste your time with 1/2 price offers. These are all BRAND NEW parts. I'm not going to give them away. A small discount but that's about it, unless you're nice, pretty, blonde, extremely ***** and looking for a date with the purchase! And NO, sending a plastic blow up doll in the mail does not count! (JERRY)
B
BadVenm
Leawood, Kansas
To save everyone time and e-mails here is the pricing on each item.
Roe S/C used 300 miles - polished and painted Sold
ported and polished S/C intake manifold - modified from stock goes with above
VEC 2 updated with 2 cards goes with above
5 psi, 8 psi, & 10 psi pulley wheels 5 lb on system, others for sale $100.00 each save $19.95 each
MSD Fuel Pump boost control $185.00 save $15.00
MSD 8.8 plug wires $65.00 save $15.00
180 degree stat and stat gasket $30.00 save $8.00
polished 70 MM throttle bodies $525.00 save $25.00
Jesel 1.7 roller rockers - 2lbs lighter per side than T&D's $1,400.00 save $75.00
Aluminum Flywheel $450.00 save $30.00
50 LB injectors $460.00 save $19.50
New Factory injector harness with new injector clips installed by Roe $180.00 save 30.00
Supercharger $15.00 save $4.00
Idler pulley $20.00 save $2.00
Modified Heads - ported, polished, chambered, bigger valves If not sold on Monday $4,400.00 save $28.00
3" Roe hi-flow Cats $220.00 save $29.00
B&B 3" cat Back $1,150.00 save 49.00
Crank keying kit and tool $50.00 save $10.00
Belanger 1-3/4" coated headers $1,700.00 save 95.00
Complete stock rear end 3:07 - change to the ratio of your choice $650.00 save $50.00
Valve covers painted and polished to match the S/C $400.00 save $125.00
Cylinder head gaskets $165.00 save $10.00
Modified air box housing w/ 3" outlets $129.00 Save 29.95
3" silicone smooth tubes - red $65.00 save $14.95
Buyer pays shipping.
countourcafe
