92-93 Valet Key
Timothy McManus
PA
Figured I would put this out there for anyone looking for a replacement key for a 92 or early 93. The standard key blank on the right in the picture only works on the ignition and won’t slide into the trunk. Seems to be a valet key only. Make sure to get the Mopar 4723480 with the 78 groove shown on the left If you want access to the trunk as well. Had to learn the hard way. Not sure if this holds true for the later models as well.
SneakyPete13
Portland, OR
Looks like this is the case indeed for 92-93.
I originally thought the only difference would be in having the black part vs. not for a valet key. I was using Mopar Part #55075487 and it worked just fine for my 94 for both the trunk and the ignition. That part # does not have the 78 groove.
