94 rear tire wear
tacodan
acquired my 94 two years ago,9500 mi,was told tires were replaced at 8000 mi,am noticing what appeares to be excessive wear outer edge of both rear tires,12000 mi.now,all in town mi.also have slow pressure loss in both(10-15lbs /3 weeks),normal or do I have a problem ???
steve e
Car needs an alignment , for the slow leak check tire to rim seal, the rims can build up corrosion where the tire bead is, needs to be cleaned, also check the valves for leaks.:usa:
VIPER GTSR 91
Spring, Texas
You have a problem for sure with the slow leak and tire wear. Remember too the life of tires is not just the miles but also the age. More than 5 years old calls for new tires especially on a performance car like the Viper. Play it safe and get new shoes. An alignment/check should be in order too.
viper2002
