'95 Head Gasket Job - FYI
dawgman
Ripon, WI
After spotting a drip of antifreeze coming from the rear of the engine about a month ago, I did an inspection to find out where it was coming from. Looked like there was seeping from the head gasket above the starter, the usual symptom for the Gen I. Interestingly enough, and here is the FYI, when I removed the coolant crossover housing from the heads, the drivers side gasket was shot. I am convinced that the leak originated from there, and made its way down the head and block so as to look like a bad head gasket. I realize that the head gaskets on the Gen I's should be changed, and I am close to finishing the job, but I just thought I would pass this along. Additionally, both head gaskets actually looked great. BTW, there are 23,000 miles on the car. Finally, thanks to all of you who posted helpful hints, and of course to Chuck Tator who is so helpful with everything!!
Stretch
VOA
Chuck Tator is the man :2tu:
Glad your head gaskets are good to go. I got mine done in 09 with mid 20k on the clock. They were leaking just a little bit at the time.
jdeft1
Metropolis
I've done four headgasket jobs in my 'shade tree' shop so far (mine, friends, local guys). Good catch on the crossover gasket leak. Believe it or not, the crossover casting on mine had a weep-thru leak! It took me three years to locate it. Drove me crazy for awhile...
VinhyVegas
