99 GTS doors not opening all of a sudden. Fobs and handles inop
GmanSRT10
I drove the car today, when I went to get out the door handle from the inside would not release the door latch...I had to use the mechanical emergency handle to get out. The handle on the outside is not working either, nor is the key fob.
Everything worked perfectly earlier today. I've checked the fuses, I made sure the eem is plugged in, everything is the way it has been. Thoughts?
speedracervr4
Lancaster, PA
The wires in the door jams are known to get broken after awhile, might be worth looking at. Both doors no working? If it's both then it's probably not the wiring.
G
GmanSRT10
I notice the red light on the dash is not blinking any more...it is both the passenger side and drivers side door. I had left the headlights on for a short time before I drove off in it...consequently it started slowly. Could this have anything to do with it? I feel like pinched wires would cause an intermittent issue.
Ross L
