Fast Too
When depressing the brake pedal I hear a whoosh sound of air in the ****-pit. Much like depressing an air foot pump. It only does it with the car running and after a couple pumps on the brake after turning it off. It has never done this before, and it started in my driveway when pulling back in the garage. I haven't road tested to see if my brakes are still functional. I plan to drive around the neighborhood to check shortly.
I am pretty sure it is a vacuum line that has come loose or something else that would leak air when depressing the brake. Car still idles fine. I tried to look up under the dash but cannot see anything. Does anyone have an 06 service manual that you can check to see what is up there that I should be looking for?
