Look at the labels attached to the a/c system to see what type of freon to use. If it is blowing hot, and is out of freon, have it pressure/die tested first. Otherwise you will be wasting money for freon, that will be taken out anyways, to fix. I don't know if car companies have reclamation tanks that allow them to reuse the freon, but normally not. Some places charge about 65 bucks to do the pressure/die test, but will drop it if repaired. On the a/c lines, there are 2 covered fittings where the freon goes. However, if you do not know what you are doing, I would not recommend it. The system is filled to pressure in terms of pounds. If you do not attach the fittings correctly, or take them off at the wrong time, etc., it can leak/get on you, and cause freon burn, which would be worse than/equal to liquid oxygen/nitrogen(the one they use to remove callouses). One reason I would also recommend taking it to a professional, is because once an a/c system leaks empty, or is taken apart, a part of the system which is like a filter, becomes contaminated. YOU DO NOT WANT TO REUSE IT!!!! (I have mindblock and forgot the name of the part) Also, since 1995/6, the EPA went on to further regulate freon, if you do not have a license, you may not be able to get it.
I was joking around the other time with you, this time it is real. Thanks for being a good sport before.
