A/C
pauls
Akron, Oh USA
Just took my 96 in for warranty. Had to put on a new condensor. Thank god for extended warranty. Didn't fair so well with the slow window. New track $280, Labor $100 not covered, Not good. This is a historic problem should be covered.
Gerald
Near Tampa Bay
hey Chuck,
I have no idea bro, but I wouldn't see why they wouldn't work. It's A/C just like other cars.. Nothing special..
Gerald
ACR Joe
Newtown, PA
My a/c was pretty marginal until I tinted the windows and lost the cats. Much improved as a result!
Rich Carlson
N. Richland Hills, Tx
A couple of things to consider. If you have the late 98 and up fan module, you will move more air through the A/C condensor which will not only improve condensor cooling but radiator cooling. One other item to look at, is the amount of R-134A refrigerant you have in the system. A R-134A is very sensitive to how well it cools based on the refrigerant level. Sometimes you will have better cooling if the system is a couple of ounces less than than specs. But adding more refrigerant will usually reduce cooling capabilties.
HavikPerformance
