jcaspar1
I have only owned my Viper for 6 months now but have learned a few things that may be worth passing along.
1st) Last week I scuffed my right front wheel. Not severely but very noticable. When I finally got over the initial grief I thought I would try and polish it out. Using 600 grit wet/dry sand paper I was able to completely remove the scuff with the exception of one deeper area. Here I took a very fine file to remove a bit more. Worked great. You cannot see any damage at all from a foot away and the wheels still have their nice shine in the area polished. The aluminum is very soft and easy to polish. Be careful not to polish any area that doesn't neeed it. I would think re-balancing the wheel would be a good idea if you remove a significant amount of metal.
2nd) I had a very annoying creak/squeek coming from behind the passanger seat. Kind of like a styrofoam squeek. I found that this was due to the panel behind the seat (filler panel?) rubbing against the panel to the rear of the passenger door. I squirted a small amount of ArmorAll between the panels and it was gone. A much quieter ride.
I hope someone finds this of benefit.
