abs sensor output
Seb
Hi,
Do any of you guys know what kind of output the abs sensor on the viper produces? AC sinewave perhaps?
thanks for the help.
seb
repiv
Hi,
seb
i'm not sure of the output, I know john reed knows. What i do know is the output (gen 3 car) with Motec TC, had to run separate motec sensors tothe tone wheel
Seb
Yeah I spoke to John. There are some things motec cannot due and utilizing the factory abs sensors as a source for wheel speed is one of them. So you just have to use hall effect sensors.
The circuit I designed is specific for reading the output from the abs sensors. We will see how it goes shortly.
repiv
Best of luck.
I am not sure if what you're doing is what John did, but he had someone build a circuitto convert a split abs signal to whatever signal the Motec reads, after fooling with it, we gave up. The signal was always too dirty
Seb
has nothing to do with a motec. The motec can only accept certain signals. We have designed a circuit specifically for abs sensors. It works perfect on gm style sensors so I am assuming they would be the same but who knows.
BarryLB
