are you taking about the forks? A good pipe wrench and a 4ft steel tube sliding over the end of wrench soak around the threads with wd-40, put in a big vice holding one leg of the fork, and then play superman to break loose They used lock tight on them , once loose they'll unscrew ok
A tip from Old FartRacing
hi just done mine they were locked on,took them to a local race shop,he had to heat them up a bit,then they came undone.ps contacted roe they said you got to heat em up a little .cheers mate
