Anyone have 3:55's with Roe SC?
VIPR GTS
xenia ohio usa
Re: Anyone have 3:55\'s with Roe SC?
I have the Roe SC with B&B headers and Corsa 3" exhaust, the
3:55 gears are from JonB. I am totally satisfied with this set up so far. I had some concern prior to adding the SC about the gears but I have found the combination to be loads of fun, thrid and fourth gears are scarry quick. The ratio is still good for 6th gear cruising and trips. The SC just makes the car pull much harder from thrid to sixth gear. You would love the combination if you tried it.
Jack B
NE Ohio
The 3.33 gears are as high as you can go in the 600 hp range and still stay in fourth thru the quarter.
VIPR GTS
xenia ohio usa
I don't know about the effects on the drag strip, never go there, but for us street drivers the 3:55 gears are perfect for everyday acceleration and just plain fun. The 3:55 also seemed to do me well at Mid Onio during Viper Days, of course that was prior to the Roe SC. I guess the conclusion is this, the gear is great fun for street drivers, may not be right if you only drag race your car.
Mando9595
