Anyone know how to Read Air/Fuel Ratio? (pics)
H8TOW8
Just dyno'ed today ... tech said the air/fuel looked good but he didn't know Vipers very well. You guys concur? Look ok? Any abnormalities?
GR8_ASP
It's the red line and the right hand Y axis. At 2500 rpm it is about 15.5:1 and at 6000 rpm about 11.5:1. The blue line is the horsepower line.
H
H8TOW8
Thanks Ron ... I should of been more clear with my question. What I am curious about is does the red curve look normal? Are the ratios of 15.5" to 11.5" normal at those rpms? Too rich? Too lean?
GR8_ASP
Guess i misread your question. The a/f looks high to me. Could it be the response time for the a/f meter? The readings look a little off as I would assume it starts off near stoich. If he was going at 2000 rpm or so part throttle for a time then it should have been running near stoich. Then it looks like it is slowly headed down to the low 11's. Which is about right so long as the meter is slow reacting and not the engine control. Where was the O2 being measured? tailpipe or exhaust manifold? The further back the more delay in the reading.
1TONY1
Dalton Ga. (Chatt. Tn.)
Also does it have cats on the exhaust ? That will change the a/f reading from what I hear. I would recommend that anyone doing a/f tuning spend the $50 bucks and get a sensor **** installed in the correct spot.
H
H8TOW8
O2 was measured in the tailpipe...might have been delayed some. Yep, Corsa full 3" exhaust with Random Tech Hi Flow Ceramic Cats. Good advice Tony ...
