Anyone know of Ron Zimmer?
Camfab
SoCal
I've heard that this guy is the Tuner of all Tuners and has cracked most ECM coding. Apparently he programmed Lingenfelters Viper cars. Anyone know this guys number or how to contact him?
C
Camfab
SoCal
I'm not certain about the logic,but I do know that he's not associated with the car company. I believe the company name is Z-Industries.
GTS-R 001
California (north)
<[email protected]>
Z" Industries
The "Z" Industries chip Program Features
Engine Power Increase. A solid 5-8HP through the entire powerband, as tested on a dyno. Better than all but the new SuperChip.
Progressive shift firmness mods based on throttle position.
Rev limiter and speed limiters raised.
A/C compressor shutoff at full throttle.
Rear gear adjustment.
Fan temperature adjustment.
Advantages
Very good progressive shift firmness: stock at light throttle, tire chirps at full throttle.
Shift points based on 1/4 mile optimizations (1-2 is a little higher than stock, 2-3 is a little lower). The chip is good for a solid .25 second in the quarter mile.
You can choose the rear gears to program for, and the temperature at which the fans should come on, and your thermostat temperature.
Large horsepower claims (26HP @ 3000RPM, 16HP @ 5000 RPM).
Custom modifications are done free for the initial programming (e.g. fan temps and rear gears), and are $100 afterwards.
Contact for "Z" Industries (Evergreen Industries) is on the mailing list.
BarryLB
