Anyone running Sidewinders with spacers?
iownedu
I'm thinking of doing a 10mm (3/8) spacer up front and a 25mm (1 inch) adapter in the rear. Anyone running that setup and have pics? Are the front wheel studs long enough for the spacer?
viper k
i have a 1996 gts with 3/8 spacers and sidewinders got the spacers and longer lugs from john b parts rack!
Viper X
Your rear tires will rub the fender lip if you make this change and hit any kind of bumps at speed.
I
iownedu
What about a 3/4" Spacer in the rear instead of the 1"?
bmw2nv2000
Adamsville, TN
3/4" will work perfect without rubbing but depending on which wheel you have you may have to have a pocket machined in the wheel centers. I did on my 5 spokes.
Viper X
If you try to lower the car at all, it will still rub.
Not sure why you'd want to install wheel spacers on this car .....
I
iownedu
Because the wheels arent even close to flush with the fenders in the rear...
I am lowering it on just Eibach springs sometime this week.
Viper X
FYI, there's a response in the most recent Viper Magazine written by Herb Helbig to a question about putting wheel spacers on Vipers.
In short, his answer is "not recommended". "It puts undue stress on the wheel studs....leading to potential failure."
Good luck,
Dan
