Ball joint grease?
carguy07
Cuyahoga Falls, OH, USA
Is Mobil 1 grease accetable to use as ball joint/tie rod end grease for our cars?
Are there any hidden spots to grease? I do not have a manual yet for my 95.
Thanks, KW.
Don Hiltz
Rainbow City, Alabama
I don't know about a '95, but on my '94, the wheels have to be removed to access greese fittings for the upper ball joints, both front and rear.
Don
Jay Lopez
Dallas, TX USA
Redline makes a hi-temp grease also. I melted the original grease in my ball joints when I got the front brakes really hot. It melted out like lava. I switched to Redline and wrapped the new ball joints in a heat reflective material (Bobby Archer). No problems since the change. I think the Mobil 1 and Redline are similar.
95Viper
Phoenix
I used the Mobil1, it's as good as it gets.
Do it when you flush the brake fluid. Wait for the manual, don't blow out the rubber boots, just squeeze until they swell.
ViperJoe
Virginia
"MOPAR" Wheel Bearing Grease #5083149AA
1lb Tub – Extreme Temperature, extreme pressure grease.
"Use on wheel bearings, ball joints, tie rod ends, clutch linkages, axle bearings, drive line splines and slip yokes."
OR
Mobil 1 Synthetic Universal Grease
jpolen21
