battery location
Hot Rod
Allen, TX USA
The battery is located in a compartment in the left rear wheel well. After removing the tire, you'll need to remove the compartment cover to get access to the battery.
Had nearly the same situation late last winter on my '99, only the battery didn't go entirely dead. I put it on a charger so I could run the engine a few times over Winter but decided to wait till Spring to replace it. You should expect the engine to idle & run rough after battery replacement as the computer has to relearn.
BarryLB
