Best way to remove cats??
Mccarlin
Chicago, IL
Hey guys,
I'd like to remove the cats this week and i wanted to know any tips or suggestions for doing so. Is this a difficult job? I was planning on cutting them out and going to the local store for some 3" pipe and some clamps for straight pipes. Is there any place specific to cut the cats? anything i should do special?
thanks!
mike
red98RT10
Greenville, MS
Hate to ask this, but are stock header pipes on a gen II, 2 1/2 inch? I have Corsa 3" after the cats.....so I think I would need a pipe with 2 1/2" fitting on one side and 3" fitting on the other side, right?
LETHAL GTS
Winnipeg, MB
Stock exhaust is 2 1/4 I beleive.
ViperJoe
Virginia
Sawsall
If you are getting 3" pipe, I take it you have a 3" catback system, in which case you will need an adaptor like you have now to go from the stock header pipe to the 3" catback
If not, you will just need 2-1/2" pipe which should swedge over the smaller stock pipe.
Good luck
2000gtsgsxr1000
Gladstone Mo Police capitol U.S.A.
I just did it.No sweat.Just take a sawzall and cut at the weld coming off the header(about at the front of your door).I measured the size of pipe to be sure and took it with me to the Zone.I had to adapt and use two clamps up front and bolted my Borla cat back right back in.Couple hour job at the most.Also needed sims on my 2000.Was told at the strip next week it was the best sounding Viper the had ever heard.It is perfect I'm leaving it alone.Stock header,no cats,and Borla catback.
Forged Horsemen
South Elgin, IL., USA
Hey, Mike saw you in the silver bullet on Randall roadyesterday afternoon twice heading south and then heading north. Looks like you were having fun. Good luck with it man.
M
Mccarlin
Chicago, IL
Hey bud!
yeah i was cruising and enjoying the car as usual. I think i've put on about 250 miles the fist week ive owned it, i cant get enough of it. :)
M
Mccarlin
Chicago, IL
Exactly the setup i will have soon! I love the borla i have but its needs a little more, im hoping removing the cats does the trick :)
M
Mccarlin
Chicago, IL
Ok guys,
doing this tomorrow. I took the sills off and on my 3" borla catback exhaust the side of the borla that attaches to the stock cats is 2 1/2" and NOT 3". Therefore i will need a 2 1/2 straight pipe to replace the cat and connect to the header (stock ones).
Im surprised the borla thats on my car has 2 1/2" coming out of the one side (3" on the exit side). I though for sure they were 3" on both sides and i would be able to use a 3" pipe to replace the cat and just get a reducer to connect it to the header. I would think that would be more of a HP gain.
Ugh, not many choices i suppose.
Viperbat
