Black lug nuts
Camfab
SoCal
I've been wondering about those as well. The thought of Aluminum sounds great from a weight savings perspective, but also sounds like a failure potential as well.
JB/SRT
Do not use aluminum lug nuts. I have never used them and never would. The manufacturers or aluminum lug nuts even say to tighten them by hand and not with impact wrench. Too much risk for a few ounces of weight savings. The shear strength even for aircraft grade 7075-T6 temper is only around 48KSI. Get some steel nuts coated (except the threads) if you want black.
Hostile
upstate NY
Do a search for"Gorilla lug nuts"they have all kinds sizes and
finishes of nuts both open and closed cap.
Skeeter
SylvanSRT
Sylvan Lake, MI, USA
take some to the local powder coater just thread them onto a bolt and get some spray paint. either way the thickness of the paint/powder coat may change the size enuf that a std. size socket wont fit any more. Maybe JonB or one of the wheel manufacturers have the answer?
XLR8SN
I can finally give someone advice to something about the Viper. :)
Anyhow, I bought the red cap McGards Spline Drives. If you want black...then look here:
http://www.mcgard.com/automotive/product.asp?page=27#SplineDrive+Installation+Kit+-+Color
The part number is 65530BK. This is for Black Chrome. Also since it is a Spline Drive, you will need the tool...part# 65300. Being that it is a spline drive, it is sort of like a lock since you will need the tool to remove them. This is for a 1/2 X 20 lug nut.
From what I have gathered...these are supposed to be of better quality versus say Gorilla locks.
Hope this helps a little.
