Bleeding brakes on a 2008 Viper . . .
rcl4668
Oregon, USA
My Viper Tech will be installing Stoptech stainless steel brake lines and Motul RBF 600 brake fluid on my 2008 Viper in the next few weeks. I have seen from prior posts that using the Motul will require more frequent "brake bleeding." I am generally familiar with the function of brake bleeding but have never done it on my 2006 nor my 2008. Can someone give me a quick tutorial or a link on how to do this at home on an 08 Viper? Is there special equipment needed or recommended for doing this in the home garage?
Thanks for your help.
/Rich
R
rcl4668
Oregon, USA
For anyone else who is interested, I found this helpful link on Stoptech's website:
StopTech : Balanced Brake Upgrades
Are there any specific issues with bleeding Viper brakes I should be aware of? Likewise, are there any helpful tools or equipment for making the job easier? (I have seen people refer to a product called speed bleeders but have no idea what they do or how they do it.) Is there a product that would allow you to bleed the brakes without having someone pump and depress the brake pedal?
/Rich
Omaha NE.
You can buy a vacuum bleeder and do this yourself. The only problem is you will not ever be able to "really bleed all the fluid and air from the system without using a DRB3 scan tool from Dodge to activate the ABS module while bleeding. You will have old fluid and possibly air in the system if not done "correctly".
R
rcl4668
Oregon, USA
Thanks Mark!
With the Motul RBF 600, my plan is to bleed the brakes before each driving school/HPDE event. I currently plan on doing 3-4 spread out from April through October this year. (I also plan to do about 3-4 novice autocross events but I am assuming that an autocross event will not generate the speeds and thus high temps associated with air/boiling brake fluid.)
In your opinion, in order for me to make sure that the brakes are bled correctly should I just have my Viper Tech do it? Do you know roughly how much a proper brake bleeding goes for?
Thanks!
/Rich
Omaha NE.
If it were my car I would have the tech do it because he will have access to the DRB. The time allotment for a full flush and bleed is 1.8 hours using the DRB scan tool.
R
rcl4668
Oregon, USA
Thanks Mark! For just bleeding just 2-3 times per year I may just go the dealer route.
/Rich
