Borla cat back install question
SSSSE YA
Simi Valley, CA, USA
Give Dan Cragin a call, he has done a lot of work with Borla's
Dan can help with any questions you may have Good luck.
The Viper Shop 310-925-9579
Sean Roe
Jacksonville, FL
Cut the reducer off the inlet and weld on a section of 3" stainless. Have done it several times.
Sean
Sean Roe
Jacksonville, FL
All it takes is the proper tubing (304 stainless) and compatable wire in the welder (304/L or 308 also work). We have lots of 3" drops if you need two.
ZX1100
Wayne, IL
Sean, just remembered that TOOOFST is just down the street here. He should be able to weld something for me. I'll check with him.
BarryLB
