Can A Viper make power with a Solid Cam at 7000rpms
V10TT
Miami Fl
I was talking today to an Engine builder that is doing the following work on a friend's viper.
The car will have a Solid Roller cam custom made by Competitions cams (cam being made right now) Custom made Solid Lifters and cutting the block to accomodated the solid lifters.
The block is being cut 400 thousands (I guess on the lifters bores or something) to accomodated teh new soild lifters.The car will have the heads ported along with the FACTORY intake ported. Two stage NOS system, Direct port and the regualr Wet kit in front of the TB's. A custom fuel system with bigger injectors etc.
The Goal is 570 rwhp at 7000 rpms!!!! on MOTOR and 950 on the Juice!!! But nobody knows how much power this combo will make or how the power curve is going to look..
BTW, it is the first Viper motor this guy works on.
The car will be controlled by a Speed Pro system...
The porject is well on its way... The motor will be Stock Cubes, with Carrillo Rods and JE pistons....
Will this WORK in the REal world.. or will this be a NIGHTMARE for my friend!!!
I've never heard of such a set up on this forum, and I know there are some fast Vipers here...
Opinios??
No members online now.
cs83
