Can I put a Gen III motor in a Gen II car?
DEADEYE
Harvey, La.
I don't think anyone's done it. For the cost, you can easily have your gen 2 motor built to your specs and out do the gen 3.
RedEnuf93
Lancaster, PA
short and exact: N O
short and exact...WHY???
PROBABLY HOOD CLEARANCE DUE TO MANIFOLD HEIGHT???
Not a problem with aftermarket or modified hood.
Hood I see as a very minor issue.
Any other WHY NOT's?
Chuck 98 RT/10
tampa, fl USA
Just a guess but something probably needs to be modified to make the airbox fit.
Headers probably are not the same.
And maybe the bell housing and/or motor mounts.
ViperJames
NY/CT
Bottom line is anything can be done with enough money, but it comes down to it is not worth it with all the modifying required. i agree that a replacing with another GEN2 motor and modifying that would be a cheaper and better performance route.
99RT10
NY
Will a Gen2 intake bolt up to the Gen3 engine to make the swap work?
Vic
Betcha there are a bunch of brackets and fittings that aren't the same. Doesn't sound like its worth the effort?
Vip08
